AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Which Coordinate Zone for CA DRGs?
7 REPLIES 7
Message 1 of 8
452 Views, 7 Replies
I've downloaded some USGS DRG files available from the California Spatial
Information Library. They are located in part of the state of California
and represented to be in the "Albers Equal Area Projection" . I've tried to
assign the following coordinate zones within AutoCAD Map5 to the source
drawings (DRGs) with no success.
1. "CATeale" (NAD27 Albers Equal Area for California, Meter)
2. "CA-VII" (NAD27 California State Planes, Zone VII, US Foot),
3. "US48" (48 States; NAD27 Albers Equal Area, 1:2000,000 DLG
Does anyone know if there is a coordinate system to pick from within the
program which will work? If not, is there one that you can modify to work
for this source?
David
7 REPLIES 7
Message 2 of 8
Hi David,
There was a bad definition for the old Map versions for the Teale
definition. I'd try modifying the CATeale definition so that the False
Easting is MINUS 4000000 instead of plus. The rest of the definition is
fine.
If that doesn't work, let me know.
Cheers,
David Walsh
"David" wrote in message
news:30116C952D99EA544D33ACEC65C97932@in.WebX.maYIadrTaRb...
to
> for this source?
> Thanks,
> David
Message 3 of 8
David,
It worked! You definitely saved my sanity. This is not the first time
you've come to my rescue. I was at the end of my rope. THANK YOU!!!
Many cheers!!!
David
David wrote in message
news:0D061CFE11DCB96DEA956FD383705F38@in.WebX.maYIadrTaRb...
> Hi David,
> fine.
> Cheers,
> David Walsh
Spatial
California
tried
> to
work
> > for this source?
> > Thanks,
> > David
Message 4 of 8
David,
I was so happy it worked, I forgot to mention one minor point for the
benefit of anyone else you may run into this... it's the false Northing that
I changed (not the false Easting).
David
> Hi David,
> fine.
> Cheers,
> David Walsh
Spatial
California
tried
> to
work
> > for this source?
> > Thanks,
> > David
Message 5 of 8
David and everyone -
Please do not change the subject line of newsgroup messages to
which you are replying. It breaks the ability of the search
engine to group the messages, makes it hard to follow the thread
and is quite confusing. If it is a new subject, please start a
new message; if a reply, put your text answer in the body of your
message and leave the header the same.
The subjects "Which Coordinate Zone for CA DRGs?", "DAVID: YOU
ARE AWESOME!" and "PS:" all belong in this message group.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Message 6 of 8
Does that include appending a useless subject line?
eg. Original post's subject line "Help"
Reply's subject line "Help - coordinate conversion"
Or can the search engine cope with that?
Huw
"Anne Brown" wrote in message
news:3DDD74D2.ECCCBDF6@autodesk.com...
> Anne Brown
> Manager, Moderator
Message 7 of 8
The search engine would find all instances of "Help". It's always
best to leave the subject line as originally started and just
reply. Moderators do routinely edit subject lines such as "help"
or "please help" as they are not specific to the problem. The
better the subject line the better the answers usually. If we do
edit a subject line, we go back to the original post so all
answers will have the ammended subject.
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Message 8 of 8
Anne,
OK. Sorry about that. Thanks for letting me know.
David
> Anne Brown
> Manager, Moderator
”Boost
