AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Where is Drive Alias Saved
7 REPLIES 7
Message 1 of 8
mathewkol
1147 Views, 7 Replies
I have a whack of users on whose computers I need to set up a drive alias.  I'd ather not go to each one, fire up Map, then go through the motions of defining the same alias for everyone?
Is there a registry key that gets set?  I could then create a REG file and simply run it on everyone's machines.
Or a file that gets changed that I could copy to the users' machines?
Something else I can do?
Thanks for the help.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
in reply to: mathewkol
Find the file ACADMAP.INI
For Win7 and Map3D2013 stored in: C:\ProgramData\Autodesk\AutoCAD Map 3D 2013\R19.0
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
mathewkol
in reply to: Alfred.NESWADBA
You da man Alfred, thanks.
Matt Kolberg
Message 4 of 8
sir,
i am a automobile engineer,i am confused  what autocad software i should expertise in begining..Autocad or Autocad Alias
please respind to me ,,and i don't have a Graphic card in my PC
Message 5 of 8
antoniovinci
No graphic card, no party, sir.
You'd better call your nearest Autodesk reseller, man.
Message 6 of 8
mathewkol
Your question is very different from the initial subject of this thread, please create a new thread instead og hijacking another.
Matt Kolberg
Message 7 of 8
sir,
sorry but i don't know how to create a new thread or ask questions in
autodesk community,i searched a lot but didn't found my answer..sorry for
discomfort
Message 8 of 8
Murph_Map
Try here and see if it helps on starting a new thread. http://forums.autodesk.com/t5/Getting-Started-with-the/tkb-p/gettingstarted
Murph
Supporting the troops daily.
