AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
When starting autocad map 2010 I get an error
6 REPLIES 6
algete
308 Views, 6 Replies
Unable to run autocad it could be due to one of the following reasons
This version of AutoCAD was not installed properly
does not have the rights to run autocad
and then get this error:
Fatal Error: Unhandled Access Violation Reading 0x3533760 Exception at 519aeeh
6 REPLIES 6
Alfred.NESWADBA
in reply to: algete
welcome @forums.autodesk.com !
As it tells you that one of the possible reasons might be "not installed properly" have you tried to run a repair-install or re-install?
Did Map3D already run on your system or have you installed it now (and so with other words it never run)?
What happens if you login to your system with another Windows user account, does Map3D then start?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
algete
in reply to: Alfred.NESWADBA
Hello Good morning, it happens with any user both administrator and normal user.
desisntalado and repaired I've tried both and nothing is coming out the same error.
3y servipack I have installed the Microsoft Net Framework 4
Thank you very much for helping
Alfred.NESWADBA
in reply to: algete
was Map3D ever running on that system?
What operating system do you have? (and other system specs).
For release 2010 it's more important that Framework 3.5 is installed (and repaired if necessary).
You might also try to start AutoCAD without hardware acceleration (look to the start-parameter /nohardware >>>here<<<) to make it more independent from specific graphiccard driver/version
- alfred -
Alfred NESWADBA
algete
Hi I have the operating system is Windows XP Professional Servipack 3 3.25 GB of Ram Intel Core 2 Duo   and the program is the AUTOCAD MAP 3D 2010 thank you very much
algete
I've tried running with / NOHARDWARE and get the same error
...was Map3D ever running on that system?
- alfred -
Alfred NESWADBA
”Boost
