style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"mugye77" <Jason,
href="mailto:mugye77@yahoo.com">mugye77@yahoo.com> wrote in message
href="news:f131fce.1@WebX.maYIadrTaRb">news:f131fce.1@WebX.maYIadrTaRb...
Any info you have about what to do if you don't know the history of the
file, would be greatly appreciated. The problem is, that i took over this
position and picked up on projects left off by the former employee. I had
similar problems when working in ArcView but luckily i had metadata to work
with. I think that these two dwgs use to align. The story with the drawings is
that one is just an enlarged splice of the other. I have a comprehensive
street atlas drawing, and then separate enlarged drawings representing each
sheet of the map. There were instances in the past where i would alter
something in the comprehensive drawing and then copy and use the PASTEORIG
command in the other drawing. Everything used to align as if they were in the
same coordinate system, but now they are slightly off. Well again, any help
would be greatly appreciated. I'm stuck.
thanks,
Paul
"mugye77" <I
href="news:f131fce.-1@WebX.maYIadrTaRb">news:f131fce.-1@WebX.maYIadrTaRb...
desperately need some answers here, and the help file is not exactly helpful.
I have two drawings that used to be aligned but are now a little "off". I'm
assuming that their coordinate systems differ. But what i need to know is how
i find out what coordinate system they are currently in. Where exactly is the
metadata for Autocad drawings?
Thanks-
Paul Bradford
"mugye77" <Hey
href="news:f131fce.5@WebX.maYIadrTaRb">news:f131fce.5@WebX.maYIadrTaRb...
guys,
new question for ya. I've determined that no coordinate system was
ever assigned to these drawings. So how is it that when i from one drawing and
pasteorig in the other, that parts of the map are almost aligned? It looks
like it might be a scale issue. Like i said someone else actually created the
original files. I'm just wondering what the process is if no coordinate system
has been assigned, that allows Cad to align images spatially?
Paul
"mugye77" <Hey
guys,
Paul
"Neil Wilson" <
href="mailto:neil_w@ci.devils-lake.nd.us">neil_w@ci.devils-lake.nd.us>
wrote in message
href="news:39CA789AF0AB6513ABB4CBAFDB1ABD60@in.WebX.maYIadrTaRb">news:39CA789AF0AB6513ABB4CBAFDB1......
All autocad drawings have coordinate systems, but
they can be arbitrary or they can be established by various agencies such as
the state plane coordinate systems. The drawings you have were created using
coordinate systems that were similar but not identical. That is why they
almost line up when you overlay them. If it is a scale issue, try
xreffing them into a blank drawing and lining them up using 2 points with
the align command. If it is a scale issue, they should line up perfectly. Do
not use rubber sheet as it will distort your data depending on what points you
use. The align command will only scale and rotate, so you won't distort
your data.
"mugye77" <Hey
guys,
and pasteorig in the other, that parts of the map are almost aligned? It
looks like it might be a scale issue. Like i said someone else actually
created the original files. I'm just wondering what the process is if no
coordinate system has been assigned, that allows Cad to align images
spatially?
Paul
"Neil Wilson" <
wrote in message
href="news:7F423A0A7C65D49BC23C119AB96027BB@in.WebX.maYIadrTaRb">news:7F423A0A7C65D49BC23C119AB96......
Correction: Use the TRANSFORM command to scale
and rotate. Align will rotate but not scale unless you respond "Yes" to the
prompt for scaling. Transform will always scale and rotate.
"Neil Wilson" <
wrote in message
href="news:39CA789AF0AB6513ABB4CBAFDB1ABD60@in.WebX.maYIadrTaRb">news:39CA789AF0AB6513ABB4CBAFD......
but they can be arbitrary or they can be established by various agencies
such as the state plane coordinate systems. The drawings you have were
created using coordinate systems that were similar but not identical. That
is why they almost line up when you overlay them. If it is a scale
issue, try xreffing them into a blank drawing and lining them up using
2 points with the align command. If it is a scale issue, they should line up
perfectly. Do not use rubber sheet as it will distort your data depending on
what points you use. The align command will only scale and rotate, so
you won't distort your data.
"mugye77" <Hey
guys,
was ever assigned to these drawings. So how is it that when i from one
drawing and pasteorig in the other, that parts of the map are almost
aligned? It looks like it might be a scale issue. Like i said someone else
actually created the original files. I'm just wondering what the process
is if no coordinate system has been assigned, that allows Cad to align
images spatially?
Paul
