AutoCAD Map 3D General Discussion
Active Contributor
rckohler
Message 1 of 12 (771 Views)
VP Freeze for Display Manager items
771 Views, 11 Replies
10-29-2012 10:14 AM
I created a drawing with multiple layout tabs, so as to create different maps. My display manager consists of data connections & layers added from the Layer Properties Manager. When I activate a viewport from the layout, I want to freeze some of the Data Connection items (like shp files). How can I freeze these items within the active viewport only?
Robyn
then you can create mulitple maps (within the dialog _MAPWSPACE) having different stylization or on/off settings of datasources.
And when you have created a viewport you can use command _MAPASSOCVPWITHMAP to assign a map-config to a viewport. If you haven't disabled ribbons you just have to change to the paperspace of a layout to get the context-sensitive-ribbon for layout-tools ==> and there are the icons for assigning maps/legends/scalebars to viewports.
Also look to some videos "what' new in Map3D 2013"
- alfred -
Alfred.NESWADBA
Message 2 of 12 (769 Views)
Re: VP Freeze for Display Manager items
10-29-2012 10:24 AM in reply to: rckohler
what version of Map3D do you have?
IMHO you need Map3D 2013 to be able to display different map's per viewport.
- alfred -
Alfred NESWADBA
Active Contributor
rckohler
Message 3 of 12 (767 Views)
10-29-2012 10:33 AM in reply to: Alfred.NESWADBA
I'm using 2013.
Alfred.NESWADBA
Message 4 of 12 (761 Views)
10-29-2012 10:54 AM in reply to: rckohler
- alfred -
Alfred NESWADBA
Active Contributor
rckohler
Message 5 of 12 (754 Views)
10-29-2012 02:31 PM in reply to: Alfred.NESWADBA
I created a new display map in model space, then used the suggested command 'MAPASSOCVPWITHMAP' to update my viewport accordingly. This seems to have worked just fine. Now I need to adjust to the thought process of Map 3D versus AutoCAD. I was very comfortable using 'VP FREEZE' in AutoCAD. So i'm basically doing the same thing in Map 3D, just in model space, verses in the layout...
I think I understand that now, please correct me if I've misunderstood, or am going in the wrong direction.
Robyn
Alfred.NESWADBA
Message 6 of 12 (750 Views)
10-29-2012 02:40 PM in reply to: rckohler
you are at the correct way! For all FDO-objects (connected gis-datasources) you have to use the different map-settings to have the aibility for different viewport-visualisation/stylization.
For the plain AutoCAD geometry like mpolygons, polylines, lines, blocks, etc you can use either the viewport-depending freeze or you can also use the map-functionality for stylize these objects (as long as they are selectable by rules). So in this case you can use two different ways to work.
HTH, - alfred -
Alfred NESWADBA
Active Contributor
rckohler
Message 7 of 12 (748 Views)
10-29-2012 03:09 PM in reply to: Alfred.NESWADBA
Yes, I understand now. Thanks again Alfred!
tjmapper
Message 8 of 12 (733 Views)
10-30-2012 01:02 PM in reply to: rckohler
Seems like it would have been easier just to use this:
Active Contributor
rckohler
Message 9 of 12 (704 Views)
11-05-2012 11:46 AM in reply to: rckohler
Yes, it sure would. Thanks!
Active Contributor
rckohler
Message 10 of 12 (618 Views)
11-29-2012 06:54 AM in reply to: tjmapper
The Layer Visibility isn't selectable under the Layout Tools tab. It displays grayed out, as your image clip indicates. How is this activated?
