Natan,
Can you give examples (I don't see any on your website) of the viewshed analysis abilities of RDV? In particular, how does it handle multi-point viewshed analysis? Can it output viewshed polygons (and in the event of multi-point visibility, viewshed polygons specifying the number of points that the polygon is visible from?)?
Andrew Schroeder
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
