AutoCAD Map 3D General Discussion
Active Contributor
amm30165
Message 1 of 2 (215 Views)
viewport is blank when creating a raster image
215 Views, 1 Replies
06-29-2012 11:10 AM
I am using MAP3D 2013 and trying to create a raster image file for use in anther document (the document will not accept a dwg or dwf file, only a raster image).
When I use the JPGOUT (or PNGOUT or BMPOUT or TIFOUT) command I can select all of the objects and viewport; there is no problem creating the file.  But when I open up the raster image, only the viewport outline and objects in paperspace have come accross; the viewport appears empty.
In MAP, the viewport is turned on and I can see everything as intended.
Any suggestions?
Alicia
antoniovinci
Message 2 of 2 (205 Views)
Re: viewport is blank when creating a raster image
06-30-2012 04:39 AM in reply to: amm30165
1] _PLOTTERMANAGER
2] add the TIFF UNCOMPRESSED device
3] plot to file by means of that virtual printer
