AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
viewport is blank when creating a raster image
1 REPLY 1
543 Views, 1 Reply
I am using MAP3D 2013 and trying to create a raster image file for use in anther document (the document will not accept a dwg or dwf file, only a raster image).
When I use the JPGOUT (or PNGOUT or BMPOUT or TIFOUT) command I can select all of the objects and viewport; there is no problem creating the file.  But when I open up the raster image, only the viewport outline and objects in paperspace have come accross; the viewport appears empty.
In MAP, the viewport is turned on and I can see everything as intended.
Any suggestions?
1 REPLY 1
antoniovinci
1] _PLOTTERMANAGER
2] add the TIFF UNCOMPRESSED device
3] plot to file by means of that virtual printer
”Boost
