AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Viewing newest version of Mr. Sid
1 REPLY 1
pasayten
208 Views, 1 Reply
I have LandDesktop 2007 with Raster Design installed on a windows XP machine. I recently got a new NAIP MrSid image and I cannot view it. I believe it is a newer version than those I have successfully inserted in the past. What is the correct patch or enabler to view these newer files?
1 REPLY 1
Alfred.NESWADBA
in reply to: pasayten
I don't think that you'll get a patch for a software that's 5 years old. If your research is correct that the fileformat is newer than your software is able to load try either to get a update for AutoCAD (but try first to load the raster data with a 30day trial version of Map and/or Rasterdesign to make sure that will sove the problem) or look to find a converter for this MrSid-files.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
