The map 2014 is very slow in FDO label . Map is unusable if the label is showing, the cursor freeze or move very very slow.
Also the same effects is in 2013 but not in 2010.
I tested on different workstation with different configuration and the behavior is same.
Albert
Hello
You are speaking about ACAD MAP 201X 32 or 64 bits ?
And with how much memory on your PC ?
How many FDO Labels ?
Are you using MText (Default option for MAP 2012-2014 FDO Labels) or Standard Texts ?
MAP 2010 + SP 2 ?
MAP 2013 + SP 1 ?
Bye, Pat
Patrice BRAUD
This function (below) if exist in Ms SQL the labeling process in map is killed.
If somebody can test I will appreciate. We test more then 7 workstation for 2013/2014 ..
But the issue is not present in 2010/2012.
Nasty function.
Hello
Sorry no MS -SQL Server !
Have you tried to generate standard Texts Labels ?
Please NOT Multi-Texts Labels (which is the DEFAULT option) !
Bye, Pat
Patrice BRAUD
