I am using AutoCAD MAP 6, in this versin i have this problem with properties
menu when i try to change the vertex.
"Marion Pietsch" escribió en el mensaje
news:33CF5C178196512550E6D6C3EC6773CD@in.WebX.maYIadrTaRb...
> Miguel,
> not sure if I understand your question correctly, but there was an issue
in
> an earlier Map version where you couldn't use the AutoCAD properties
windows
> to 'walk along' the vertices of a polyline with the arrow keys of your
> keyboard. Is that what you're referring to?
> Then, the only workaround is to use the pedit command.
> However, if your question is another one, please describe it a bit more in
> detail.
> Thanks,
> Marion Pietsch
> Autodesk Professional Services
> Infrastructure Solutions
> "Miguel Angel Sosa" wrote in message
> news:1FF68C6929EC14DA291686F621FB78BD@in.WebX.maYIadrTaRb...
> > I have a problem with the properties menu, when i try to change the
> vertex,
> > in vertex option, after selection the polyline, the button not responds,
i
> > suppose that i need to change any variable. Any idea ?
> > thanks all.
