AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Using FDO to attach a MR SID image-failure
6 REPLIES 6
518 Views, 6 Replies
I downloaded a MR SID (latest version) from RGIS.edu, our local GIS clearinghouse in New Mexico, to add to a drawing file. After downloading it, I extracted the data to a folder (still under my Downloads folder) and tried to connect it to my drawing via FDO. I got a message saying that there was a problem and it could not connect to the file. I am using Civil 3D with all service packs.
I never had much of a problem in the past connecting to downloaded aerials. I resist inserting this type of image because of the possibe poor coordinate transformation and/or file size bloat.
I found a topic about repaiing broken feature connections in the Help, but I am not certain that it applies in my case.
Do I need to move the folder to my temporary reference file location?
Also, I could not find much information online about this topic. Thank you.
Susan H
6 REPLIES 6
parkr4st
what version of C3D?  Are the files present with the SID: .prj, .sdw? how much memory are you working with on your system?
Dave
Alfred.NESWADBA
what happens if you try command _MAPIINSERT instead (just to verify if the file is defect or the FDO-connection has an issue ...)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
I will ive it a try-pretty busy today, but will try to find the time.I don't usually have problems with files from this source.
Susan
in reply to: parkr4st
Sorry, I meant to write C3D 2012, machine has 8 g of RAM.
I did a bit more digging and it may be a permissions issue. I can Image-insert the SID to a drawing, just not connect to it via FDO. It seems that the compressed file download is read-only, because my Downloads folder is locked (local office policy). I am going to try downloading it again to the C:\ drive & see if it is still read only. I can take read only off the extracted files, but FDO still fails to load the SID.
I will mess with it some more next week, and maybe do some negotiations with the IT administrator. Thanks for the follow-up.
Susan
Alfred.NESWADBA
Just copy it to a temp-folder on C:, then right-click it to see the files properties and disable the read-only flag (if there is one).
- alfred -
Alfred NESWADBA
”Boost
