Hi I want to do something similar to a LOOKUP or Reclassify. I have an autoCAD file of road centerlines I have exported to SDF with three different colors 10,162, and 256. Now what I want to do is use the CALCULATE function to add a new property to the attribute table called "type"
IF COLOR =10 THEN 'Arterial'
IF COLOR =162 THEN 'SubArterial'
IF COLOR =256 THEN 'Local'
in QGIS I would write the following SQL: CASE( WHEN "COLOR" = 10 Then 'Arterial'....
how to do a similar reclass in MAP3D???
as far as I know that is not possible with Map (unfortunately).
One workaround might be:
- export to SQLite instead of SDF
- use SQLite tools to create new column and then update column using SQL
Rob
Why not just create a new SDF file with this information in it? Put all of you Color 10 lines on an "Arterial" layer, Color 162 on a "Secondary Arterial" layer, etc, then rebuild the SDF add the layer name when exporting.
I know it doesn't directly answer your question about using lookups, but it is an easy fix for your immediate problem.
I would suggest the following approach.
1. Create a new SqLite file (in AutoCAD Map) with just FeatID and two atribute fields and without geometry field.
2. Open the SqLite file in an external browser and fill in the data.
Field 1 Field2
10 Arterial
162 Sub-arterial
256 Local
etc.
3. Back in AutoCAD Map, create a JOIN between the original SDF file and the new SqLite file using Field1.
This way, the SqLite is used as a 'lookup' file. It requieres a few steps, but works fine !
Greetings, Jack Melgers
What do you need to with the three designations after the data is in the table?
Hello parkr4st,
The auxiliar file (for instance in SqLite) is just to create a 'lookup' table (10 >> Arterial).
After creating the JOIN you can use the new field to create map labels (Arterial, Sub-Arterial, etc) or a thematic map.
I don´t think it´s possible in AutoCAD Map to do this in just one step by creating a calculated field.
you can do that with style without the extra column of data.
theme on you color field, reset the line colors to the three numbers you use and width or a particular line style as you chose, the legend label for each class of road, Feature label to each type of road. You can adjust various settings to get the final appearance you desire within the limits of the selections available with Map3D
Dave
OK, parkr4st, that´s right !
Anyway, the original question was how to create an additional column with this information. But you´re right, perhaps it´s not necessary, it depends on what the user wants to achieve.
Greetins, Jack Melgers.
Hi!
During conversion from DWG->SDF you can just use "Feature Class Property Mapping". You can create directly property field "Type" based object property "Color", just mark that color 10=Arterial, color 162=SubArterial and 256=Local. So you dont need to do any calculation anymore.
