If you are using database links (Link Path Names) there will be a conversion
process where the R14 format is translated to the R2000/2002 Link Template
format. This is a bit confusing to setup but works pretty well once you get
the stars aligned correctly.
Cheers,
Will
"barry.wheeler" wrote in message
news:3B795950.C7D72AAF@eub.gov.ab.ca...
> We will be upgrading very shortly from Map3 to Map5. Has anybody
> encountered any installation problems or had to do some 'work arounds'?
> Thanks in advance,
> Barry
