AutoCAD Map 3D General Discussion
Member
0 Kudos
Post 1 of 6
Unit issues with georeferenced images
299 Views, 5 Replies
12-22-2011 10:57 AM
I am an autocad and ESRI user who is trying to better intergrate the functions with Map 3d.  I am having problems with drawing units when connecting to GIS data.  I live in TN, so I have set the coorinate system to TN NAD 83, Feet.  When I connect in a NAIP aerial, it displays properly.  When I measure anything, however, the distances are off by a factor of about 1/3.  That is, something that is supposed to be 18' is measuring 6'.  I have played with the units, but can't seem to come up with an answer.  Any help would be appreciated.
Valued Mentor
35 Kudos
Post 2 of 6
Re: Unit issues with georeferenced images
12-22-2011 12:45 PM in reply to: brake76
metric?  3.281 feet = 1 meter
dave
Member
0 Kudos
Post 3 of 6
12-22-2011 12:53 PM in reply to: brake76
That thought did cross my mind.  I have played with the different units coordinate systems,  and nothing changes.  Here is the only pertinent information from the USDA image metadata:
patial_Reference_Information:
  Horizontal_Coordinate_System_Definition:
    Planar:
      Grid_Coordinate_System:
        Grid_Coordinate_System_Name: Universal Transverse Mercator
        Universal_Transverse_Mercator:
          UTM_Zone_Number: 17
            Scale_Factor_at_Central_Meridian: 0.9996
            Longitude_of_Central_Meridian: -81
            Latitude_of_Projection_Origin: 0.0
            False_Easting: 500000.0
            False_Northing: 0.0
    Geodetic_Model:
      Horizontal_Datum_Name: North American Datum of 1983 (NAD83)
      Ellipsoid_Name: GRS1980
      Semi-major_Axis: 6378137.0
      Denominator_of_Flattening_Ratio: 298.257222101
I didn't see anything about units.  Anyone know if the UDSA aerials are in metric, and if so, how to correct this?  I have sucessfully connected to shapefiles and google earth images, so I am pretty sure it is something with the aerial itself.
207 Kudos
Post 4 of 6
12-22-2011 02:54 PM in reply to: brake76
IIRC some of the images from USDA are in metric even when the metadata states otherwise. Where abouts in TN are ya?
Murph
Supportting the troops daily.
Distinguished Mentor
35 Kudos
Post 5 of 6
12-22-2011 03:47 PM in reply to: brake76
USDA is metric.  Are you using FDO or MapIINSERT?  make sure you set the drawing coordinates to metric if using mapiinsert.  fdo will transform, mapiinsert wont... you need to insert in metric and perform a drawing query to transform utm meters to nad feet if not using FDO...
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Member
0 Kudos
Post 6 of 6
12-27-2011 07:51 AM in reply to: brake76
I have tried using mapiinsert and connecting to the SID file via the task pane (connect to data) and get the same result.  When I connect to shape files that weren't provided by USDA, everything comes in to scale and in the right location (even if i created the shape file in ArcGIS drawing on top of a USDA aerial).  Both image and shape files directly from USDA come in scaled to metric and in the wrong location.  I have never had these problems in ArcGIS.  Any ideas?
