AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Unit issues with georeferenced images
5 REPLIES 5
brake76
566 Views, 5 Replies
I am an autocad and ESRI user who is trying to better intergrate the functions with Map 3d.  I am having problems with drawing units when connecting to GIS data.  I live in TN, so I have set the coorinate system to TN NAD 83, Feet.  When I connect in a NAIP aerial, it displays properly.  When I measure anything, however, the distances are off by a factor of about 1/3.  That is, something that is supposed to be 18' is measuring 6'.  I have played with the units, but can't seem to come up with an answer.  Any help would be appreciated.
5 REPLIES 5
parkr4st
in reply to: brake76
metric?  3.281 feet = 1 meter
dave
brake76
That thought did cross my mind.  I have played with the different units coordinate systems,  and nothing changes.  Here is the only pertinent information from the USDA image metadata:
patial_Reference_Information:
  Horizontal_Coordinate_System_Definition:
    Planar:
      Grid_Coordinate_System:
        Grid_Coordinate_System_Name: Universal Transverse Mercator
        Universal_Transverse_Mercator:
          UTM_Zone_Number: 17
            Scale_Factor_at_Central_Meridian: 0.9996
            Longitude_of_Central_Meridian: -81
            Latitude_of_Projection_Origin: 0.0
            False_Easting: 500000.0
            False_Northing: 0.0
    Geodetic_Model:
      Horizontal_Datum_Name: North American Datum of 1983 (NAD83)
      Ellipsoid_Name: GRS1980
      Semi-major_Axis: 6378137.0
      Denominator_of_Flattening_Ratio: 298.257222101
I didn't see anything about units.  Anyone know if the UDSA aerials are in metric, and if so, how to correct this?  I have sucessfully connected to shapefiles and google earth images, so I am pretty sure it is something with the aerial itself.
Murph_Map
IIRC some of the images from USDA are in metric even when the metadata states otherwise. Where abouts in TN are ya?
Murph
Supporting the troops daily.
thepworth
USDA is metric.  Are you using FDO or MapIINSERT?  make sure you set the drawing coordinates to metric if using mapiinsert.  fdo will transform, mapiinsert wont... you need to insert in metric and perform a drawing query to transform utm meters to nad feet if not using FDO...
brake76
I have tried using mapiinsert and connecting to the SID file via the task pane (connect to data) and get the same result.  When I connect to shape files that weren't provided by USDA, everything comes in to scale and in the right location (even if i created the shape file in ArcGIS drawing on top of a USDA aerial).  Both image and shape files directly from USDA come in scaled to metric and in the wrong location.  I have never had these problems in ArcGIS.  Any ideas?
”Boost
