If you key in CUI, and change the "Command List" to "All Commands and Controls", an Unhandled Exception is generated.
See attached.
I cannot reproduce this in AutoCAD 2012. Also you screenshot seems to be not from pure AutoCAD.
What product exactly is it that you are running?
Best regards,
Silvia
Silvia Menon
Support Specialist
Product Support
http://www.autodesk.com/autocad-support
Hello and thanks for the reply. I am using Autocad Map 3D 2012 64 in Win 7 Pro. My mistake - I considered this an issue in core Autocad. About reports this as Product Version: F.51.0.0.
Can you move the post to Map 3D for me please?
no problem, I have now moved the thread from the AutoCAD forum to the AutoCAD Map 3D Forum.
Best regards,
Silvia
Silvia Menon
Support Specialist
Product Support
the behavior you described with the CUI showing up the message with choosing “All Commands and Controls” is due to a known issue that is currently under investigation by our development team.
Unfortunately there is no possible workaround to avoid this message. However, in general the error message doesn’t affect product functionality, and it is possible to click “Continue” for working without any other message and having the full functionality of the CUI.
Kind regards
Brigitte
