AutoCAD Map 3D General Discussion
Active Member
MeagenM
Message 1 of 7 (2,528 Views)
Unhandled Access Violation Reading 0xffffffff
2528 Views, 6 Replies
05-21-2012 12:45 PM
Please help! I've had numerous fatal errors every day using 2013 Map 3D. This one is the most common error that pops up. I believe it's centered around raster images and caching or regenerating. I didn't have this issue in 2012.
I have tried so many fixes including:
  • Repairing (about 3 times)
  • Clean uninstall following Autodesk steps (1 time)
  • uninstall and reinstall (4 times)
  • Clearing temp files after a crash
  • Verifying Windows updates / anti-virus
  • Turned off automatic saves
I'm running on Windows 7, 16GB RAM, 64 bit OS, 220 GB Hard Drive. (computer isn't the issue)
I'm at a loss...
Distinguished Mentor
thepworth
Message 2 of 7 (2,512 Views)
Re: Unhandled Access Violation Reading 0xffffffff
05-21-2012 02:17 PM in reply to: MeagenM
What type of Raster(s) and how are they connected - FDO or MAPIINSERT?
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
thepworth
Message 3 of 7 (2,509 Views)
05-21-2012 02:58 PM in reply to: thepworth
Also, are you getting the CER - Customer Error Report window popping up with the crash?  If so, fill it out and if you're also on subscription, you can go and file a support request through subscription center and the folks at Autodesk can respond to your support request while seeing the CER information for what specifically is causing the crash (hopefully).  I'd say that is your best avenue....
C3D 2011
New Member
rtaylor
Message 4 of 7 (2,441 Views)
05-30-2012 12:13 PM in reply to: MeagenM
I'm getting the same error message but mine happens when I try to export to sdf2 from Map 2013.
Member
athornton88
Message 5 of 7 (2,277 Views)
07-26-2012 01:59 AM in reply to: MeagenM
I am getting this same issue but I am using AutoCAD 2010. It only happens when I import a dynamic block I have made (the only actions in this are visual states and there are 6 of them). I have created other dynamic blocks that work with visual states with no problem so why the errors?
Member
athornton88
Message 6 of 7 (2,274 Views)
07-26-2012 03:46 AM in reply to: MeagenM
Just solved my problem. I was using a hatch in the block and once I removed this it was fine. I am guessing that this error is used for multiple problems though due to the forums I have seen so far.
antoniovinci
Message 7 of 7 (2,267 Views)
07-26-2012 04:11 AM in reply to: MeagenM
MeagenM wrote:
Please help! ... I'm at a loss...
You just spent thousand of $ to buy Map2013, so the only place to complain is the headquarter of your Autodesk dealer, madame...
