AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Undo command disabled? Crash'n'Burn...
2 REPLIES 2
Oakbank
1859 Views, 2 Replies
Constantly getting this message with one particular drawing:
"Warning! Undo has been disabled in order to prevent undo file overflow. You may re-enable it via the undo command. The undo file length was 1857669610 bytes"
What exactly does this mean? How can I remedy?
Using a 64-bit install, the drawing has imported .shp files and a georefenced DOI (x-ref'd)... doing some prelim road design work. AutoCAD generally crashes on me with this particular drawing (~1.65 M in size).
...banging on the keyboard isn't helping.
Thanks.
2 REPLIES 2
rmacan
in reply to: Oakbank
If you type the command "UNDO", the command line should show options associated with the command.  You can limit the amount of commands that UNDO will store, or temporarily disable it altogether.
Another option is from this posting:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/UNDO-file-size/td-p/3739258
Good luck!
Randy
Oakbank
in reply to: rmacan
Thanks Randy - will try 'em all and see what happens.
”Boost
