AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Unable to import .shp file multiple times
1 REPLY 1
afine1
400 Views, 1 Reply
Hi.  I'm using Autodesk Map 3D 2006, it's a new install.  I am trying to import an ESRI .shp file with the object data, but have only been able to successfully import it once.  When I try again (even after restarting the program), I keep getting 0 objects processed and no linework imported, even with new drawings.  I also got 2 error messages at one point: 1900 - about having coincident points and a can't transform object error.  I have been looking for any information to explain these errors more and how to fix them.  Has anyone else run into this problem and have a fix?  Any help would be greatly appreciated.  Thank you.
Tags (2)
1 REPLY 1
Murph_Map
in reply to: afine1
Look in the folder that has your shp,shx, and dbf files for that shape file and see if there is an idx file, if so delete it and try.
Murph
Supporting the troops daily.
”Boost
