AutoCAD Map 3D General Discussion
Distinguished Mentor
thepworth
Message 11 of 12 (219 Views)
Re: Unable to conect to excel file using ODBC FDO provider
05-03-2012 01:03 PM in reply to: chierchio
in this case, the data is extended attributes (water quality sampling for MCL's) against existing wells.  Since the I'm attaching to a .SHP from the state well data set, I'm intending to perform a join to stylize points based on the sampling results.  so, I haven't tried to add points by their coordinates.  When I have some time, I'lll try & let you know what happens.
TdH
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Valued Contributor
chierchio
Message 12 of 12 (214 Views)
05-05-2012 08:01 AM in reply to: thepworth
I was finally able to connect to the excel file and map the points.
There was a duplicate point in the spreadsheet that I missed. Created another column with IDX(index) and everything works now.
Thanks for your input.
C
