AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
UCS_Rotating Current View
5 REPLIES 5
tgifford
474 Views, 5 Replies
Is there a way to rotate your view in model space without actually rotating the objects? The file is set up in an awkward position and is a little tough to work in this orientation. I know there is a way to do this in Microstation but havent figured out how to do it in AutoCAD.
We've been working in paperspace and did the dview/twist command in the viewport but would love to be able to work in model space at a certain orientation.
If anyone has any thoughts, please let me know. Thank you -
5 REPLIES 5
in reply to: tgifford
you can use dview twist in model space too ...I use as the selection....I use it all the time without fail
tawstudio
how do you twist the view in v2014?   i just got this new version and i can't figure it out in the view manager...
Alfred.NESWADBA
in reply to: tawstudio
Just use the viewcube, it's that easy, you don't need to start any command.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
tawstudio
in reply to: Alfred.NESWADBA
thanks...however, i need to clarify...am working in 2d and autocad lt 2014...i don't believe i have viewcube...
Alfred.NESWADBA
at least it exists in the help of AutoCAD LT >>>here<<<.
- alfred -
Alfred NESWADBA
”Boost
