AutoCAD Map 3D General Discussion
abr6304
Message 1 of 6 (944 Views)
Turn off Layout Tools Contextual Tab
944 Views, 5 Replies
04-23-2013 05:41 AM
How do I disable the layout Tools Contextual tab in Autocad map 2013 so that is does not become active every time I change to Paper Space. I would like the ribbon to stay focused on the HOME tab when in paper space.
Thaks to every one
Alfred.NESWADBA
Message 2 of 6 (923 Views)
Re: Turn off Layout Tools Contextual Tab
04-23-2013 10:06 AM in reply to: abr6304
have you look to RIBBONCONTEXTSELECT (>>>details<<<)? Is that what you are looking for?
- alfred -
Alfred NESWADBA
abr6304
Message 3 of 6 (909 Views)
04-23-2013 10:52 PM in reply to: abr6304
Sorry for my english it's not my usual language. :manembarrassed:
I like to have the ribbon switch when, for exemple, I click on an Xref but not when I come on one layout.
I would like to stop this change and only this one, not the others switchs.
The command "RIBBONCONTEXTSELECT" speak about "the first ribbon contextual tab defined in contextual tab states"
Can't I change these "contextual tab states" to stop the switch for layout and only this one ?
Thank's for your answers
Alan
olivier.eckmann
Message 4 of 6 (901 Views)
04-23-2013 11:57 PM in reply to: abr6304
you must customize your CUIX file (I'm not sure of terms, because I use french version):
- at command line enter  CUI
- in the upper left clic on "+" near "Ribon" ("Ruban" in french)
- clic "+" near "State of contextual tab"  ("Etat des onglets conceptuels" in french)
- clic "+" near "Layout tools" (last line "Outil de création" in french)
- right clic on the contextual tab and choose "remove" ("Outils de création contextuels" in french)
make a backup copy of your CUIX before modifying it.
Olivier
abr6304
Message 5 of 6 (898 Views)
04-24-2013 12:04 AM in reply to: olivier.eckmann
Cher Olivier, merci de votre réponse, je vais tester votre solution.
Comme je l'ai signalé dans mon mail précédent la langue de shakespeare ne m'est pas particulièrement familière.
J'ai beaucoup plus de facilités avec la langue de Molière (bien que ma version d'Autocad soit en Anglais)
Bien à vous
Alan
abr6304
Message 6 of 6 (893 Views)
04-24-2013 12:19 AM in reply to: olivier.eckmann
Grand Merci Olivier
Solution testée et approuvée
:manvery-happy:
Je vais propager cette solution parmis mes collègues car plusieurs d'entre eux se plaignent de cette "commutation automatique"
A+
Alan
