AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Turn off Layout Tools Contextual Tab
5 REPLIES 5
abr6304
3042 Views, 5 Replies
How do I disable the layout Tools Contextual tab in Autocad map 2013 so that is does not become active every time I change to Paper Space. I would like the ribbon to stay focused on the HOME tab when in paper space.
Thaks to every one
5 REPLIES 5
Alfred.NESWADBA
in reply to: abr6304
have you look to RIBBONCONTEXTSELECT (>>>details<<<)? Is that what you are looking for?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
abr6304
Sorry for my english it's not my usual language. Man Embarassed
I like to have the ribbon switch when, for exemple, I click on an Xref but not when I come on one layout.
I would like to stop this change and only this one, not the others switchs.
The command "RIBBONCONTEXTSELECT" speak about "the first ribbon contextual tab defined in contextual tab states"
Can't I change these "contextual tab states" to stop the switch for layout and only this one ?
Thank's for your answers
Alan
olivier.eckmann
you must customize your CUIX file (I'm not sure of terms, because I use french version):
- at command line enter  CUI
- in the upper left clic on "+" near "Ribon" ("Ruban" in french)
- clic "+" near "State of contextual tab"  ("Etat des onglets conceptuels" in french)
- clic "+" near "Layout tools" (last line "Outil de création" in french)
- right clic on the contextual tab and choose "remove" ("Outils de création contextuels" in french)
make a backup copy of your CUIX before modifying it.
Olivier
abr6304
in reply to: olivier.eckmann
Cher Olivier, merci de votre réponse, je vais tester votre solution.
Comme je l'ai signalé dans mon mail précédent la langue de shakespeare ne m'est pas particulièrement familière.
J'ai beaucoup plus de facilités avec la langue de Molière (bien que ma version d'Autocad soit en Anglais)
Bien à vous
Alan
abr6304
Grand Merci Olivier
Solution testée et approuvée
Man Very Happy
Je vais propager cette solution parmis mes collègues car plusieurs d'entre eux se plaignent de cette "commutation automatique"
A+
Alan
”Boost
