AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
trim or break a 3dpolyline at a specific z coord
14 REPLIES 14
Message 1 of 15
shallowhead
754 Views, 14 Replies
Say we have a line that goes from 0,0,0 to 10,0,10.
How can i trim or break that line (or snap another line to it) at a specific z coord? say at elev 5.51?
14 REPLIES 14
Message 2 of 15
antoniovinci
in reply to: shallowhead
1] command _BREAK
2] select object
3] type 10,0,5.51
4] type @
Message 3 of 15
braudpat
in reply to: antoniovinci
Hello Antoniovinci
Superb / Excellent !
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 15
User48
Have you actually tried this?  One can assume you forgot to enter F for First Point after selecting the object.  Even then AutoCAD returns this.
Command: BREAK
Select object: (pick polyline)
Specify second break point or [First point]: F
Specify first break point: 10,0,5.51
Specify second break point: @
At least one break point must be on polyline.*Invalid*
Message 5 of 15
antoniovinci
in reply to: User48
Yessir, here's my F2 output:
Command: l LINE Specify first point: 0,0
Specify next point or [Undo]: 10,0,10
Command: break
Select object: L
Command:
By the way, the _F option is involved when you pick an object.
Message 6 of 15
shallowhead
Yes thanks. However, I was hoping for there was a lisp or another command (similar to LENGTHEN) where you could set the z coord at 5.51 and then just pick the line and it would trim it at that elevation. I have many lines all at different positions that form contours of a top of bank and bottom of ditch. Given those elevations I need to create another contour line in between them at a given z elevation.
Message 7 of 15
shallowhead
in reply to: User48
I have not tried it. However, I was hoping for there was a lisp or another
Kevin Trasorras
CADworks
813-996-9775
ktcadd@gmail.com
Message 8 of 15
User48
So it works with LINE objects, but the OP wants to break 3DPOLYLINES.
Message 9 of 15
antoniovinci
in reply to: User48
It doesn't matter, sir: the above technique works with 3Dpolys too, both with _L and with _F (as right stated by you).
Message 10 of 15
parkr4st
should the first break point be 5.51,0,5.51?  Your input gives the break at 7.7405,0,7.7405 for me
dave
Message 11 of 15
Murph_Map
in reply to: parkr4st
dave
That's the difference between 2006 and 2010 & up, Relative and absolute coordinates on input from the keyboard.
Murph
Supporting the troops daily.
Message 12 of 15
User48
Can you provide a complete working script?  This content based on your posts does break the 3DPOLY but it breaks it at the wrong elevation.  Please provide a full script to demonstrate breaking it at elevation 5.51.
_3DPOLY
0,0,0
10,0,10
_BREAK
_L
10,0,5.51
Message 13 of 15
antoniovinci
in reply to: User48
My fault, gentlemen, I wish to apologize for that, 'cause the point 10,0,5.51 does not belong to the line 0,0,0-10,0,10 indeed.
I don't see an easy solution, I mean without using trigonometry.
On the other hand, the _SLICE command (by Z=5.51 plane) works only with solids, not with simple lines.
Sorry again...
Message 14 of 15
braudpat
Hello
Sorry for my answer, I thought that Antonio has the right solution !?
Maybe I have a "stupid/bad" solution which needs a few commands !
So a Lisp/VLisp programm will be very useful ...
Draw a SOLID (Box in fact) : Height = 5.51 - which "includes the line" ...
Explode the SOLID, so you get 3DFaces ...
Draw a Line from (.xy) at beginning (Snap=END) of your line (0,0,0)
when asking for Z; click with (Snap=NEA) at the Face (which is at Z=5.51)
then draw the line with Ortho ...
I think that the Intersection of your first line and "my" line is the point you were looking for !?
Bye, Pat
Patrice BRAUD
Message 15 of 15
TerryDotson
If you were to consider third party software, MapWorks Base contains two tools to handle this.  First is 3dPoly Mark Elevations which marks all points of a specified elevation along a selection set of 3dPolylines.  Second (and most important in this case) is 3dPoly Break At Elevation which breaks a selected 3dPoly at a specified elevation along a segment (also preserves Extended Entity Data on the newly created polyline).
”Boost
