AutoCAD Map 3D General Discussion
New Member
ian.hourston
Message 1 of 6 (1,619 Views)
Transparent Polygons plot improperly to PDF
1619 Views, 5 Replies
06-20-2012 11:58 AM
When I plot to PDF, polygons plot with dark lines radiating from points along it's boundary, (see attached).  If plotted correctly, the polygons should have a uniform appearance. What I have learned so far:
  • It only happens with transparency turned down in the style.
  • I tried several methods including Adobe, DWG to PDF, PDF Report Writer, and Vadim PDF Writer.
  • It was plotted from a different machine, same result.
  • It was plotted by a different user, same result.
  • It happens with other drawings.
  • It also happens with solid hatches, but does not seem to be as bad.
  • It does plot to the plotter correctly, at least!
Ian
Valued Mentor
parkr4st
Message 2 of 6 (1,613 Views)
Re: Transparent Polygons plot improperly to PDF
06-20-2012 12:10 PM in reply to: ian.hourston
this is discussed. searching the forum for   "hatch & pdf"   offer solutions.  some are depending on the version of map you have.  what plotter did you use?
http://forums.autodesk.com/t5/AutoCAD-2007/solid-hatch-striated-in-pdf/td-p/1937684/page/2
 from that link
If you're using the plotter "PDFCreator", try changing it to "DWG To PDF.pc3". That should remove the lines.
dave
New Member
ian.hourston
Message 3 of 6 (1,595 Views)
06-22-2012 03:10 PM in reply to: ian.hourston
Thanks Dave,
I did a  search for the discussion you cut and pasted from, but I do not think I found the same one. In one case, there were screen shot of a PDF with the polygons with parallel streaks, In my case, the streaks radiate. There was a observation that a PDF displayed correctly on some machines but not on others. My PDF has displayed the same on  all the computers I tried, and the resulting plots to a printer are as displayed on the screen.
I am using Map 3d 2012, service pack 1.
Plotter drivers tried:
Yes I have tried DWG to PDF. I have also tried Adobe, PDF Report Writer, and Vadim PDF Writer. I also plotted to a DWF first, then to PDF.
Ian
Product Support
phil_borycens
Message 4 of 6 (1,592 Views)
06-22-2012 04:48 PM in reply to: ian.hourston
The issue of numerous fine lines appearing in transparent (or semi-transparent) FDO polygons when outputted to PDF is under investigation by both the Map 3D and AutoCAD development teams. Fixes have been discussed, but a conclusion has not yet been reached.
You should see better results by plotting to DWF. Anyone can download the free Design Review or Design Review Mobile (iOS, Android) application to view DWFs.
I have linked your case to the change request for this issue, which should draw further attention to it.
I'm sorry for the inconvenience that this has caused you.
Phil Borycens
Barry_Wheeler
Message 5 of 6 (424 Views)
06-11-2014 08:58 AM in reply to: phil_borycens
I have not seen any fixes on this topic and we are having the problem in Civil 2014 using filled shapefiles with solid transparent hatch. We have tried Adobe and the DWG to PDF drivers (while tweaking pararmeter within) but this has not solved it.
Has any progress been made by any users or the Autodesk development team?
Product Support
phil_borycens
Message 6 of 6 (399 Views)
06-12-2014 02:50 PM in reply to: Barry_Wheeler
Hi Barry,
I just tested it in the 2015 release and see that it's still an issue.
Researching further, it looks like this may have fallen off the radar due to a switch to agile development (new tracking system and methodology).
So I just logged a new change request about it (#DE14029) and linked it to this forums thread.
Unfortunately I cannot guarantee that this will make it into a sprint but at least it is back on the radar.
Phil
Phil Borycens
