Hi, I have points from a surveyor that are in Nad83 (Deg/Min/Sec) that I want to digitize into my drawings that have the same Nad83 Coordinate. The problem I have is, I need to translate the Deg/Min/Sec to Decimal so that I can input.
Is this possible?
Thanks.
What form are the points in? on paper, dwg file, shp file?
You can use 'bd to manually enter the info. deg.minsec ie 25.2436
if the a dwg file are the points already located correctly oin the NAD83 system? draw lines between them may be enough
Dave
Down load the free program from the Army Corp of Engineers CORPSCON6
Program converts between datums NAD27, NAD83, Geoids, UTM, State Plane......
Inputa data in CSV file format PXYZD
Jim
Here is a link.
http://crunch.tec.army.mil/software/corpscon/corpscon.html
If you are in a hurry and can't install, go here:
http://www.fcc.gov/mb/audio/bickel/DDDMMSS-decimal.html
Jay
