AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Transfer text created in Task Pane to a Layer
5 REPLIES 5
718 Views, 5 Replies
Dear all,
I am using MAP3D 2012 and have the following query. Under Task Pane and Display Manager I have added drawing data to a drawing layer. Added Style>Text and selected the Object data I want to have displayed (e.g. drawing number).
Since the drawing is going to be accessed also by users with a simple AutoCAD version I want to copy paste the text from display Manager to a Layer In layer Properties  Management.
However, every time I create a new layer and copy paste the text does not appear or carry through.
What I am doing wrong?
Thank you for your help.
5 REPLIES 5
braudpat
Hello from France
I am not sure to well understand your problem !?
Why you don't let only this text layer ON, then doing a MAP FDO Export to DWG ?
The only way to see OD (Object Data) for NON MAP/CIVIL AutoCAD users is to have real text !
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
antoniovinci
in reply to: braudpat
Bonjour, monsieur.
I think the OP is talking about Map's task pane layers, not about 'normal' Autocad layers...
braudpat
in reply to: antoniovinci
Hello Antonio
If we are speaking about FDO text layers !
My solution 1 is OK :
>>> Why you don't let only this text layer ON, then doing a MAP FDO Export to DWG ? <<<
Command (maybe): MAPTOACAD     = Save Current Map to AutoCAD
and then INSERT the DWG created in 0,0 (Exploded)
so you will get "good real" AutoCAD texts ...
Bye, Pat
Patrice BRAUD
hence_the_name
you can use the command "maptoacad" (since 2012 I think). It will convert a "Map" drawing with DisplayManager elements (drawing data or fdo data) to a vanilla CAD drawing. use export option "editable", a template is not required (only works with fdo data).
good luck,
rob
http://raumpatrouille3d.blogspot.ch/
Murph_Map
@Anonymous wrote:
Dear all,
You need to do an alter property query and change the layer for the text there.
Murph
Supporting the troops daily.
”Boost
