I have a drawing with Objects that have both Object Data and Linked data in an Access database. I need to get information from the linked table to a new linked table for each object.
I have thought that if I get the necessary information from the Linked table record to the object data for each object, I could then convert the Object data to a new link and am looking for a way to copy the data from a field in the Linked Table to the object data. There is at least one field common to both the OD and Linked Table record.
Is there any automated way to transfer this data?
Solved by Murph_Map. Go to Solution.
Whoa, it's hard to follow ya, sir, especially at this hour (11 p.m. CET).
Would you please graphically sketch your goal, in a flow chart fashion..?
Mapexport to sdf/shp select both the Object Data and link table as the data. Then mapimport and create object data from the attibute data.
Hello
+1 with Murph, it's the best solution and very easy ...
So you get ALL Infos as Object Datas and now you are autonomous !
Bye, Pat
Patrice BRAUD
@torentrue wrote:Thanks for your help. I apologize for the delay in responding.
Thanks again,
No problem, as long as it works for you.
