AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
total newbie quick question
2 REPLIES 2
2165 Views, 2 Replies
Hi people,
I know almost nothing about Autocad. Got the Autodesk Map 2000 installed here.
Today, something came up. I need to draw a metal part to send to guys that will cut and fabricate it.
I have the original one here. So i took some measurements and started drawing. But is in 2D.
If they ask for 3D, what software should i look for?
It's just a silly metal plate. But it have different heights on corners. I do have a print of it, with the profiles (see below). The steel is 5 mm thich.
Thanks for your help.
Thiago
2 REPLIES 2
bingeomatics
In Autodesk Map you can modeling 3d objects, too.
Binnat Khalilov
”Boost
