AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
thick lines of attached dwg files in the paper space
2 REPLIES 2
CS94
362 Views, 2 Replies
Hi
I want to print the drawing from the paper space, but I have there thick lines of attached dwg files. In the model space everything seems to be OK. Do you have any idea how to change it?
CS
2 REPLIES 2
Murph_Map
in reply to: CS94
Are you using plot styles? In the plot dialog you can select not to plot using plot styles or use the standard acad style.
Murph
Supporting the troops daily.
CS94
in reply to: Murph_Map
Thanks for your answer. I tried to set plot styles but I think that the problem is creating by blocks which are in the attached drawing (perhaps some settings of plot are connected to the settings of blocks).
”Boost
