Robert,
If I understand your problem correctly, I think that the thematic query
option will definitly work for you. I use the thematic query to color fill
geologic maps routinely based on a geologic label. It doesn't matter to Map if
there are 2 or 2,000 polygons (i.e. parcels), the colors are filled in
automatically in a few seconds as solid hatching patterns. I use object data
definitions rather than blocks, but I believe you can use your block attributes
just as easily as I use object data to do the same thing. Since I teach a GIS
course, I have summarized the steps in making a geologic map with a thematic
query in the below document on my web site:
http://www.usouthal.edu/usa/geography/allison/gy461/1_24000GeoStand.pdf
Sections VI and V would probably be of most interest to you. If you have not
created a polygon topology, sections I through III will be important.
If you don't have any luck I wouldn't mind taking a look at your file. Sometimes
it's necessary to look at a specific situation,
Good Luck,
David
"Robert J." wrote:
> I have a question about thematic mapping... I work in the Survey dept, and
> when a plat is done, the client likes to see colored maps, based on the
> product that is going on each lot. When I define my parcel, the software
> labels the lot with the appropriate lot number. This lot number is a block
> which contains 4 attributes.. One of these attributes is edited by me (I add
> the product definition). I would like to be able to produce this colored map
> by quering this information out of that block.... Is this possible? And if
> so, I can't seem to get it to work... I have asked this before, and wasn't
> able to get any of the answers to work.... I have had someone write a VBA
> program that will allow me to add the product information as I label the
> lots, to automate the process somewhat.... There has got to be a faster way,
> than having a tech spend a couple days hatching lots....
> Thanks for the help!!
> Robert J.
> Associate Surveyor / CAD Manager
> Stanley Consultants, Inc.
David T. Allison
Department of Earth Sciences
136 LSCB
University of South Alabama
Mobile, AL 36688
(334) 460-6381
http://www.usouthal.edu/usa/geography/allison/index.htm
