AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Thematic Map
2 REPLIES 2
407 Views, 2 Replies
Thematic Map
Hi there. I need some help. I am trying to make an tematic map and i want to enter at the value an interval. For example i want to dysplay all constructions that were made between 1980 and 2012 and i dont know what to write at the Value. I've tried to enter (1980,2012) but is not good
2 REPLIES 2
antoniovinci
You can stylize your FDO layer, but here's my "old school" method:
  1. in an empty drawing, load your DWG (containing Object Data) with _ADEDRAWINGS command
  2. issue _MAPTHEMOBJ
  3. set colours according to the OD values, then Proceed
  4. zoom extents
If all went fine, you should obtain something like this:
 Under thematic Rule....enter the expression CONSTYR     >=  '1980'    AND   CONSTYR     <=    '2012'. Not sure what your field names are but substitute the property name as needed. This will query only those years between 1980 and 2012 from which you can change the color value.
John
”Boost
