AutoCAD Map 3D General Discussion
Valued Contributor
larsj
Message 11 of 20 (136 Views)
Re: Texts aren't rotated after Map Export DWG to SQLLite
06-12-2012 05:30 AM in reply to: Alfred.NESWADBA
Now the value is the same, both in the DWG and the sqllite database, but when I connect to the database and use the rotation value it seems that it interprets it as degrees even though I have the correct units etc in the drawing. I'm stumped. I've attached the DWG in question, if you have time it would be great to hear if you get some other result...
Alfred.NESWADBA
Message 12 of 20 (134 Views)
06-12-2012 05:35 AM in reply to: larsj
what AutoCAD-Map3D version do you use? Just ot make the tests with the same release and you will then be able to use my data.
- alfred -
Alfred NESWADBA
Valued Contributor
larsj
Message 13 of 20 (132 Views)
06-12-2012 05:39 AM in reply to: Alfred.NESWADBA
Autocad Map 3D 2011 product version E.208.0.0.
Alfred.NESWADBA
Message 14 of 20 (130 Views)
06-12-2012 06:51 AM in reply to: larsj
sorry, most of the time I spent was to reduce the video to the max-upload-limit of 1.5MB (I love it :smileysad: ). I hope the quality is enough to recognize what I typed.
Try to reproduce what I did (within your drawing).
HTH, - alfred -
Alfred NESWADBA
Alfred.NESWADBA
Message 15 of 20 (128 Views)
06-12-2012 07:02 AM in reply to: larsj
and additionally the data I created (just the text-objects, no MTEXT).
I had save all (DWG and SQLite-file) in C:\TEMP
- alfred -
Alfred NESWADBA
Valued Contributor
larsj
Message 16 of 20 (126 Views)
06-12-2012 07:14 AM in reply to: Alfred.NESWADBA
You've done a hell of a job, thanks for putting in so much effort!
I noticed that you where able to choose text on the map export form but I don't have those options on top. I have attached a picture of my form.
I'll use this video and/or your export if I can't get it to work myself. Thanks!
Valued Contributor
larsj
Message 17 of 20 (124 Views)
06-12-2012 07:26 AM in reply to: Alfred.NESWADBA
And one final thing. Have you tried connecting to the database from a new drawing, adding the texts to the map via a style? I did that with your database and got the same phenomenon - the texts aren't rotated properly... :smileyfrustrated:
I'm starting to think that I'm a dumbass. :smileytongue:
Alfred.NESWADBA
Message 18 of 20 (120 Views)
06-12-2012 07:45 AM in reply to: larsj
I have modified the MAPEXPORT.INI file in th section of SQLite (in orange the changed part), so you get the object-types also available to chose.
   [FDO_SQLITE]
   File=True
   Rootname=False
   EntTypes=Types
   FeatureClass=Single
   CreateClassBy=None
   SupportsAppend=False
Search through your workstation through all folder (also through hidden ones) for a file called MAPEXPORT.INI and modify that option. Restart Map3D then.
May be I don't understand you correctly ... have you modified the style also in the new drawing with the formula for rotation
TXT_ANGLE / 3.14159 * 180
If you opened my drawing (drawing and db-file placed in C:\TEMP) do you see the rotation then or not?
- alfred -
Alfred NESWADBA
Valued Contributor
larsj
Message 19 of 20 (117 Views)
06-12-2012 07:49 AM in reply to: Alfred.NESWADBA
I forgot the formula! Now it works perfectly. I think I exported it correctly, all I was missing was the formula in the style. I've learned alot, thanks!
Alfred.NESWADBA
Message 20 of 20 (115 Views)
06-12-2012 07:50 AM in reply to: larsj
You're welcome! - alfred -
Alfred NESWADBA
