AutoCAD Map 3D General Discussion
Valued Contributor
larsj
Message 1 of 20 (231 Views)
Texts aren't rotated after Map Export DWG to SQLLite
231 Views, 19 Replies
06-12-2012 03:36 AM
I wan't to export a DWG-file with texts to a sqllite database to be used i MapGuide. The export is successfull but I can't get the rotation of texts to work properly - all the texts are horizontally aligned and not rotated. For example, the ROTATION field of a text in the sqllite database has the value 4.8376865658545531 - in the DWG the rotation property is 192.0233g - but when using the ROTATION field as the value for Rotation in the style label it isn't being rotated. Am I doing something wrong?
Regards
Lars Jensen
>> I noticed that you where able to choose text on the map export form but I don't have those options on top
I have modified the MAPEXPORT.INI file in th section of SQLite (in orange the changed part), so you get the object-types also available to chose.
   [FDO_SQLITE]
   File=True
   Rootname=False
   EntTypes=Types
   FeatureClass=Single
   CreateClassBy=None
   SupportsAppend=False
Search through your workstation through all folder (also through hidden ones) for a file called MAPEXPORT.INI and modify that option. Restart Map3D then.
>> Have you tried connecting to the database from a new drawing, adding the texts to the map via a style?
May be I don't understand you correctly ... have you modified the style also in the new drawing with the formula for rotation
TXT_ANGLE / 3.14159 * 180
If you opened my drawing (drawing and db-file placed in C:\TEMP) do you see the rotation then or not?
- alfred -
Alfred.NESWADBA
Message 2 of 20 (229 Views)
Re: Texts aren't rotated after Map Export DWG to SQLLite
06-12-2012 03:40 AM in reply to: larsj
IMHO the ROTATION-value is measured in radiant (based on PI) and not degrees.
So you can make a function like
ROT_DEGREE = ROT_RADIANT / PI * 180
HTH, - alfred -
Alfred NESWADBA
Valued Contributor
larsj
Message 3 of 20 (225 Views)
06-12-2012 03:58 AM in reply to: larsj
So when I export from a DWG to sqllite it converts radiants to degrees and that I need to convert the value in the sqllite database? If so, do you know why it converts the value?
Alfred.NESWADBA
Message 4 of 20 (221 Views)
06-12-2012 04:23 AM in reply to: larsj
The strongly correct answer is: because Autodesk did it this way :smileywink:
The answer (I think) is that it has to be one default or there must be any config-files parallel to the SQLite-export that gives the information of what angle-units you are using, what angle is the north-direction and so on.
So it's done easy, no config-files and just one default.
- alfred -
Alfred NESWADBA
Valued Contributor
larsj
Message 5 of 20 (220 Views)
06-12-2012 04:30 AM in reply to: Alfred.NESWADBA
Ok, but I don't really understand how 192.0233g can be converted to the value 4.8376865658545531. Any idea?
Alfred.NESWADBA
Message 6 of 20 (218 Views)
06-12-2012 04:38 AM in reply to: larsj
4 question, then I start to think about what your settings may be:
  • what is your UNITS-setting in your DWG?
  • how is your north-direction set in the DWG?
  • what is your position angle-direction? Clockwise or counterclockwise?
  • are you sure that you measured your object while WCS was active (and not any UCS/UserCoordianteSystem)
Or use this alternative: copy the drawing erase all but this one text-object and upload this new drawing.
- alfred -
Alfred NESWADBA
Valued Contributor
larsj
Message 7 of 20 (215 Views)
06-12-2012 04:49 AM in reply to: Alfred.NESWADBA
Units = Meters
Northdirection = 100.0000g
Angle = Grads (type) and clockwise
I'm not sure what you mean. I haven't measured any objects but there is a coordinate system specified in the drawing. Could that have something to do with it? The drawing was sent to me, I haven't produced it myself.
Alfred.NESWADBA
Message 8 of 20 (212 Views)
06-12-2012 04:56 AM in reply to: Alfred.NESWADBA
you are working 100° based (don't know how it's called in english, in German it's "Neugrad")
and you have your system rotated to another 0-direction then the export does
and you have another positive angle direction.
Look to this sketch:
HTH, - alfred -
[EDIT] Sorry answers crossed, I have not seen that you already answered before [/EDIT]
Alfred NESWADBA
Valued Contributor
larsj
Message 9 of 20 (208 Views)
06-12-2012 05:09 AM in reply to: Alfred.NESWADBA
I think I understand the problem, but I don't know how to fix it. I tried changing the northdirection to 0 and changing units (in format-> units) from Grads to Decimal Degrees but I still get the same result in the sqllite database. That makes me believe that perhaps I don't understand the problem as I thought... :smileytongue:
Alfred.NESWADBA
Message 10 of 20 (206 Views)
06-12-2012 05:12 AM in reply to: larsj
You have to:
  • change your angular untis to "RADIANT"
  • your 0-direction has to point to east
  • your angular direction has to be counter-clockwise
....that brings you to the same settings in AutoCAD like the exporter does (hope so, have not tried it at the moment).
Hope now that makes it more clear!
- alfred -
Alfred NESWADBA
