AutoCAD Map 3D General Discussion
New Member
14078610659
Message 1 of 4 (557 Views)
Text information from shp file to dwg
557 Views, 3 Replies
08-16-2012 02:17 AM
Hi. I have a problem importing text information from shp file to dwg. Using a command “Add to Map” I can see that shape file consists of Map Feature(s) objects and under Feature Properties there is an information that I need to move to Autocad environment (IGDS_TXT_;TEXTSTRING; TEXT_ANGLE). I’ve tried “mapimport” command  but in result I’ve got only acad point objects with no information in it. Thx
after you add the shp, display manager, select the shp; style; feature labels
as mentioned above, you can label the FDO features in Display Manager or you when you  import the attribute data it can be used for labelling as well (Map annotation or using DisplayManager again for annoation of drawing objects).
But there is a third option. The column names indicate that the SHP files might have been created with Map, using the export option "Text" (_mapexport > Shape > Text). But you can also import point featues eitehr as block or text. Here ist the procedure for importing as ACAD text:
1 mapimport > SHP file
2 click on <ACAD_POINT> in the "Points" column
3 a small button with three dots appears on the right
4 click on it
5 dialog box "How to process points" or something along the lines appears
6 choose second option, "create text from attribute data " and select "Textstring" column
Unfortunately it will ignore Text_angle and text_size or any other format setting. But depending on your data it might be a usefull option for importing.
Good luck,
Rob
antoniovinci
Message 2 of 4 (554 Views)
Re: Text information from shp file to dwg
08-16-2012 02:40 AM in reply to: 14078610659
During _MAPIMPORT, pay attention to this, sir.
Valued Mentor
parkr4st
Message 3 of 4 (549 Views)
08-16-2012 02:45 AM in reply to: antoniovinci
Robert_Fritz
Message 4 of 4 (539 Views)
08-16-2012 05:00 AM in reply to: 14078610659
4 click on it
Good luck,
Rob
http://raumpatrouille3d.blogspot.ch/
