AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Text Field question.
3 REPLIES 3
636 Views, 3 Replies
I asked this a long time ago and never got an answer.
Versions: 2008, 2009, 2010.
We have a number of drawings with map scales on them. The scales have the numbers set up as text fields. Those fields are connected to the viewport, and a standard scale system to preset scales. 1"=1/4 mile, etc. Atop the scale bar are single numbers: 0, 1/2, 1; etc.
At the halfway point, you obviously put in the number that is half of the actual. So 1/2, for 1 mile, 1/4 for 1/2 mile, etc. To do this, I simply put in the formula for the custom Scale - Units (none) divided by 2.
The problem is that on our drawings we get the pound sign instead of the formula on the halfway point when we save, regen or switch tabs. In order to to print, we have to print each one, one at a time after updating the field. We have switched from standard text to Mtext and back again. what is the problem?
3 REPLIES 3
Try FIELDEVAL =31
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Versions: 2008,
2009, 2010.
At the halfway
problem?
No go.
Here is a screen shot:
jmurphy
Does UPDATEFIELD update them? What is DEMANLOAD set at?
Murph
http://Map3d.wordpress.com
”Boost
