Starting Map 3D I get these errors about .arx load failed.
See the image!
The Task Pane is missing and some features are not working properly.
I removed the program and all the sytem files and then reinstalled the Autocad again - three times!
But the problem still remains!
Is the OS making this mess?
Any solutions???
Solved by teflon. Go to Solution.
Solved by parkr4st. Go to Solution.
read this
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
you may have to uninstall again a clean out the registry items. backup things, be careful!!
Does work, been there done that.
dave
Thanks!
I will try it!
But is there any solution to the first problem?
I do not wish to make a new installation every time Task Pane is missing!
I use the View menu but it says in the command window "there is no such a command...".
Take a look att the JPG I mailed.
I figure it out!
The problem was a recently installed program that for some reason disturbed AutoCAD. I still do not know why or how!
I suspect that and then started gradually clearing out the hard drive of any other program one by one. Once that software was gone AutoCAD was up and running nicely!
I have contacted the company regarding this program conflict and requested an explanation if there was a record of such a problem, if so why they did not warned users.
I hope this will help others still searching for their missing Task Pane 🙂
This software is made by a small company here and I guess it is only used in this country so far.
But the problem was messing up some FDO.
This bug is fixed in their latest release, they told me.
I still have to Type mapwspace every time I open Map 3D. Even if I have saved the UIC
