style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<Hey
href="mailto:warren.medernach@imaginit.ca">warren.medernach@imaginit.ca>
wrote in message
href="news:6188581@discussion.autodesk.com">news:6188581@discussion.autodesk.com...
fieldguy, I've seen similar problems when querying multiple drawings that has
'the same' Object Data tables defined in each of the drawings. Although in
reality, the tables were NOT exactly the same: the field name might have been
spelled differently, or a different data type was assigned. When Map sees
this, it gets confused because the tables might be named the same, but are
actually different. Regardless, you should be able to rename/delete Object
Data tables in the Define Object Data dialog. I'm not sure what Workspace you
work in, but the command call is: adedefdata Hope this helps. Warren
M
