AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Symbols from raster images blocks
7 REPLIES 7
Message 1 of 8
enter-st
425 Views, 7 Replies
Hi!
I have block file. Some of blocks are drawing objects and some blocks are small raster images. I have point layer, and I have connected to that layer through display manger. Then I try to edit layer syle, trying to apply symbols from block file. Every simblo is visible, except those raster picture symbols. I can see symbol name in library but symbol is not displayed on layer.
thanx
7 REPLIES 7
Message 2 of 8
andy62
in reply to: enter-st
hi,
I have the same problem
no one has solved this problem?
andrea
Message 3 of 8
What problem? You replied to a thread from 2005 and a lot has changed
between those 5 years.
Can you provide more info and what it is you are trying to do? Along with
the version of Map3D you are using?
Murph
http://map3d.wordpress.com/
"andy62" wrote in message news:6388361@discussion.autodesk.com...
hi,
andrea
Message 4 of 8
andy62
Hi Murph,
thanks for your answer
but What problem?
the problem is exactly the same of enter-st, despite all changes from 2008 or 2005 (?)
my blocks contain small bmp images and like enter-st said
"Then I try to edit layer syle, trying to apply symbols from block file. Every simblo is visible, except those raster picture symbols".
I use Map3d 2009
regards
andrea
Message 5 of 8
Andrea,
Those that use newsreaders for the discussion groups do not see the original
thread from years ago, so that's why I asked what problem. Are you trying to
style the points from a data connect layer or standard AutoCAD objects?
Murph
"andy62" wrote in message news:6388546@discussion.autodesk.com...
Hi Murph,
but What problem?
or 2005 (?)
I use Map3d 2009
regards
andrea
Message 6 of 8
andy62
Murph,
now I've got your "what problems" 🙂
thanks
I trying to style the points from an sdf data connection layer
andrea
Message 7 of 8
There's no easy way of doing it. What you need to do is convert the block to
a image file (pgn format) then used the enhanced stylization options.
This will give you an idea on what is involved.
http://map3d.wordpress.com/2010/01/14/custom-line-types-with-data-connect/
This may of be of some help also for the point style.
http://www.rand.com/imaginit/1/pdfs/technology/software/building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf
I haven't try it for points.
Murph
"andy62" wrote in message news:6388593@discussion.autodesk.com...
Murph,
thanks
andrea
Message 8 of 8
andy62
mmmh!
nothing to do!
I insert a block width image on C:\Program Files\AutoCAD Map 3D 2009\Sample\db_samp.dwg file
and I wrote two xml files (the difference is only the name of block in blockname tag)
the fisrt work width this point style with an graphic block:
false
false
Centimeters
DeviceUnits
0.3
0.3
0.0
CHAIR7
FFC69C6D
FF726358
the second does not work width this point style with an image block:
false
false
Centimeters
DeviceUnits
0.3
0.3
0.0
person
FFC69C6D
FF726358
in the enhanced stylization options and the document that you've suggested (building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf) I have not found solution.
But a specific reference could be reading this sentence:
The image itself may either be specified in the Content element as base 64 encoded PNG.
I will try tomorrow with a similar image
regards
andrea
”Boost
