Greetings!
I am at my wits end with an issue. I imported data from a SHP file to a base drawing I plan to use to attach, and I wanted to replace data points with data symbol definition blocks. However, when I create a symbol style and try to edit it by double-clicking, I get a *Cancel* on the command line and nothing happends. When I pressing the "Style" button on the Display Manager tab in the Task Pane, same thing.
I suspect that I missed a step - or several - along the way of importing the SHP file. I would appreciate any help...and please, be gentle - I am starting just learn GIS.
Thanks!
if you get unknown command (or something similar) I would say you are missing some paths pointing to the Map3D-functionality/-libs, but getting "CANCEL" is new to me, so to make sure where you press buttons upload a screenshot where you are clicking and what is "Display Manager" for you (at least I don't know that as I'm using a german version of Map3D).
Please find also attached a screenshot from my Map3D 2014 showing the paths that are needed for Map3D:
HTH, - alfred -
