AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Street labels disappear on UCS rotation when not World
2 REPLIES 2
Jfactory
309 Views, 2 Replies
Hi, this is a similar question to this post that was not resolved.
When I am in the World _plan view everything appears fine. When I use _plan to orient the view to a custom UCS the labels disappear.
As pictured:
I'm using a Dell Precision T3600 with 8 Gig RAM dual 2.8GHZ processor
Windows 7. Autocad Map 3D 2013 64-bit
NVIDIA Quadro 600 graphics card.
2 REPLIES 2
Jfactory
in reply to: Jfactory
Weirdly this is what you get when you disregard and print. What's that dashed line? Oh, it's a label and 1 of 2 that showed up.
ChadRoberge
Where is the Layer located in terms on the heirarchy in your task pane?  I have had the issue since 2011 and the answer I received back then, or maybe my own findings, was that label layers worked only when the bootom most layer.  Just above Map Base.
”Boost
