AutoCAD Map 3D General Discussion
Valued Contributor
nik.mazreen
Message 1 of 4 (1,079 Views)
.str format data
1079 Views, 3 Replies
03-14-2012 02:43 AM
is there any way to work with string file (.str) from autocad map 3d?any fdo provider support this type of format data?
thx in advanced..
-nik-
Not directly, I think.  You might look at Safe to see if they have it listed: http://www.safe.com/fme/format-search/ .  Otherwise, exporting from the source in a more common format will be the best option.
antoniovinci
Message 2 of 4 (1,078 Views)
Re: .str format data
03-14-2012 02:54 AM in reply to: nik.mazreen
Which of the following ones do you refer to..?
http://www.fileinfo.com/extension/str
Product Support
NateMoore
Message 3 of 4 (1,059 Views)
03-14-2012 12:48 PM in reply to: nik.mazreen
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Valued Contributor
nik.mazreen
Message 4 of 4 (1,051 Views)
03-14-2012 05:57 PM in reply to: NateMoore
thx for the reply..
actually this string file (.str) is created from the software called GEMCOM SURPAC.
i think you are right, i guess the best way to read this format in map 3d is to convert it to common format.
