When I click on 'show start menu', all the tabs (file, edit, view, insert, format, tools, etc....) appear on the screen multiple times, wrapping to a second line on my program. How do I stop this from occuring? If anyone has suggestions, I'd greatly appreciate it because I honestly have no idea what do.
I just installed the new 2014 Autocad Infrastructure Design Suite, and I'm using Autocad Map 3D 2014.
-Chrystal
Those are menus, controlled by the CUI for the current workspace. To turn them all off set MENUBAR = 0 then turn on the ribbon with RIBBON.
If you want to use the menu then open the CUI select the workspace on the left side then expand the menu item on the right side and right click on the ones you want to remove and select Remove From Workspace.
I suspect the Menu items got migrated from autocad vannila and added to the workspace.
