AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Start Menu Appearing Several Times - Autocad Map 3D 2014
1 REPLY 1
cchuter
280 Views, 1 Reply
When I click on 'show start menu', all the tabs (file, edit, view, insert, format, tools, etc....) appear on the screen multiple times, wrapping to a second line on my program.  How do I stop this from occuring?  If anyone has suggestions, I'd greatly appreciate it because I honestly have no idea what do.
I just installed the new 2014 Autocad Infrastructure Design Suite, and I'm using Autocad Map 3D 2014.
-Chrystal
1 REPLY 1
Murph_Map
in reply to: cchuter
Those are menus, controlled by the CUI for the current workspace. To turn them all off set MENUBAR = 0 then turn on the ribbon with RIBBON.
If you want to use the menu then open the CUI select the workspace on the left side then expand the menu item on the right side and right click on the ones you want to remove and select Remove From Workspace.
I suspect the Menu items got migrated from autocad vannila and added to the workspace.
Murph
Supporting the troops daily.
”Boost
