AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
SSA - Storm and Sanitary Analysis - import from industry model
5 REPLIES 5
hallgrimurmar
1674 Views, 5 Replies
Hi
Anyone using Storm and Sanitary Analysis from a wastewater industry model?  I have been looking into that  but have run into a problem regarding units (using metric units).  When importing data from wastewater industry model into SSA it assumes that pipe dimensions are given in meters and subbasins area are given in ha.  My data is in mm and sqr.m.
Can I define what units to use when importing this data??
If I import GIS data (shp files) I can define what units the data is in.
Using 2013 versions of Map and SSA.
with regards
Hallgrímur
5 REPLIES 5
Matt_Haokip
in reply to: hallgrimurmar
Can you go to Input | Project Options and make sure that the Unit System is US Units and then import the data? If the issue still persists, please attach the data.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
hallgrimurmar
in reply to: Matt_Haokip
Hi
Thanx for the reply.
It does not matter if I change the units in Project Options.  No matter what the values are there by default.  It seems that when exporting from Map to SSA it changes these values automatically no matter what they were before.
Not able to attach my dwg file becouse of file size limit.
with regards.
Hallgrimur
Matt_Haokip
Please open a support request so that you can upload the files and we can research into the issue further.
Matt Haokip
hallgrimurmar
Hi
Managed to trim the file down.
with regards
Hallgrimur
Another thing that I did notice is that the pipe length value in not coming through either.
with regards.
Hallgrimur
”Boost
