AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
split polygon
5 REPLIES 5
2481 Views, 5 Replies
split polygon
Does anyone know how to split polygon?
I am using "bpoly" function when I split the polygon but It's unconvenient
Do you guys know better way to split polygons?
ps. I go over the functions through help desk.
5 REPLIES 5
nwray
Try the command "mpsplit".  You should be able to select the polygon to split, then draw a line where you want the split to be made (or select an existing line), and it will split it into two new polygons.  It will also give you the option to copy over data from the original polygon to the new ones.
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
Tags (2)
maherich
Hi is there any way how to split FDO Polygons?
Martin
Alfred.NESWADBA
in reply to: maherich
command _MAPFEATURESPLIT (>>>details<<<)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
maherich
in reply to: Alfred.NESWADBA
I placed a wrong question. FDO works but I actualy wanted to ask how to split the industry model objects. I know that in some industry models there are special functions to do that. But I did not found any generell that would work for all of the objects of the geometry type.
The only way I know is to extract the geometry process it and attach the geometry beck to industry model object.
Any other hints?
antoniovinci
in reply to: nwray
Sounds like the OP's not using Mpolygons, sir.
If the polyline to split is closed, first he would transform it with the _MPOLYGON command (working on circles too).
By the way, in my Map2006 the existing splitting line must be a Lwpolyline, while simple lines don't work.
”Boost
