I have two sets of points with object data. I want to join the two sets of
data based on the location of the points. As in attach some (or all) object
data from one set of points to the object data table of the other set of
points. The data to be attached should be the data from a point in the first
set that is closest to a point in the second set.
This is similar to Arcview's "spatial join" Also I would then like to be
able to draw a line between then points that have been joined.
It would also be nice to set maximum search diameter where is a point has no
data within a specified radius, no data is joined.
Any assistance would be appreciated.
Sean Bartleet
