AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
some commands doesn't work after last service pack update
11 REPLIES 11
Message 1 of 12
2176nicola
751 Views, 11 Replies
Hi
after install the last service pack, I can't use the MAPPOLYLINETOPOLYGON command, it works only for the first time;
also, I've personalized the acad.pgp file, changing some commands, but some don't work (as EQ=matchprop); they work right before updating
How can I solve?
11 REPLIES 11
Message 2 of 12
For what version of Map3D?
I tried it with Map3D 2013 now, it works as expected.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 12
Sorry
Autocad Map 2013
Edit:
I solved for the Matchprop command modifing the acad.pgp again, but for the MapPolylineToPolygon command the problem remains
Message 4 of 12
great ;(
I installed now the SP1 for Map3D 2013 and yep, now I also can't start command MAPPOLYLINETOPOLYGON more then once. Every next command start writes the command in the commandline, but instead of asking for an object the command ends immedialty. Time for a report to Autodesk.
Sorry, no sultion, just commited, - alfred -
Alfred NESWADBA
Message 5 of 12
Gary_Braun
in reply to: 2176nicola
Confirmed here too. Blah.
Message 6 of 12
2176nicola
up.. nobody?
Message 7 of 12
>> up.. nobody?
Are we (Gary_braun and me) nobodies?
Or what are you asking now?
- alfred -
Alfred NESWADBA
Message 8 of 12
Certainly not.. I mean nobody else? 🙂 (sorry, my English is a bit rusty)
Message 9 of 12
Gary_Braun
Besides this thread, I've submitted an official bug report to Autodesk, so they are now fully aware of the potential problem. They will evaluate it to see if it's a legitimate issue, how serious, whether or not it warrants a hot fix or SP1+, etc., and then they'll either fix it or they won't. But having hordes of people jump onto here with a bunch of "me too's", likely won't advance the situation much.
-gb
Message 10 of 12
Thank you!
I'm not sure about that, because every report of a bug is followed by a mail from Autodesk to provide a "business case" for that problem (at least ADN's are asked for that). And the more people are suffering from an issue the higher the priority to repair it.
- alfred -
Alfred NESWADBA
Message 11 of 12
olivier.eckmann found >>>here<<< the >>>Map3D 2013 - SP1 hotfix 1<<< to that issue 😉
- alfred -
Alfred NESWADBA
Message 12 of 12
Many thanks 🙂
”Boost
