Hi
after install the last service pack, I can't use the MAPPOLYLINETOPOLYGON command, it works only for the first time;
also, I've personalized the acad.pgp file, changing some commands, but some don't work (as EQ=matchprop); they work right before updating
How can I solve?
For what version of Map3D?
I tried it with Map3D 2013 now, it works as expected.
- alfred -
Sorry
Autocad Map 2013
Edit:
I solved for the Matchprop command modifing the acad.pgp again, but for the MapPolylineToPolygon command the problem remains
great ;(
I installed now the SP1 for Map3D 2013 and yep, now I also can't start command MAPPOLYLINETOPOLYGON more then once. Every next command start writes the command in the commandline, but instead of asking for an object the command ends immedialty. Time for a report to Autodesk.
Sorry, no sultion, just commited, - alfred -
>> up.. nobody?
Are we (Gary_braun and me) nobodies?
Or what are you asking now?
- alfred -
Certainly not.. I mean nobody else? 🙂 (sorry, my English is a bit rusty)
Besides this thread, I've submitted an official bug report to Autodesk, so they are now fully aware of the potential problem. They will evaluate it to see if it's a legitimate issue, how serious, whether or not it warrants a hot fix or SP1+, etc., and then they'll either fix it or they won't. But having hordes of people jump onto here with a bunch of "me too's", likely won't advance the situation much.
-gb
Thank you!
I'm not sure about that, because every report of a bug is followed by a mail from Autodesk to provide a "business case" for that problem (at least ADN's are asked for that). And the more people are suffering from an issue the higher the priority to repair it.
- alfred -
olivier.eckmann found >>>here<<< the >>>Map3D 2013 - SP1 hotfix 1<<< to that issue 😉
- alfred -
